jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
Flash008
May 02, 2017Luminary
Netgear Moderators,
I would like to attempt one last method to fix these multiple problems with the Orbi product.
Rather than complaining, and throwing away my $600 investment, perhaps the Netgear engineers and developers would be perceptive to suggestions which I am sure can resolve some (if not all) of these problems.
First, let me say Thank You!
Thank you for your attempts to create an appealing looking product. It doesn’t look like a science project gone wrong with 6 antennas and 10 LED lights. It doesn’t cause my guest to ask me, “What is that weird looking thing”.
Thank you for your attempts to innovate and solve the large home WIFI coverage problem.
Thank you for the speed. Yes, its fast!
With all that you made right, some portions of the Orbi product are missing the mark.
I believe I may know what you are overlooking.
You tried to create an EASY, SIMPLE, and high tech product that could be used by anyone, especially non-technical consumers. Unfortunately, what you “may” be missing is the reality that no one solution for WIFI exist for everyone. Therefore, other WIFI OEMs allow access to advance settings enabling consumer to tweak and tune the product to their specific use case and environment.
Homes, buildings come in a large variety of sizes, floor plans, building materials and other variables which can cause interference from other locations. Possibly home appliances and other devices which may not “play friendly” with Orbi, despite your best attempts to find the one configuration that works for everyone. It’s just not possible!
Hence, I ask of you. I plead with you. Beg of you! Stop trying to make Orbi work for everyone using your locked-in configurations. Allow some flexibility!
Here are my suggestions which have proven to be affective for all of you competitors. Many of these suggestions have been posted in your” ideas” area forum. We must assume you are too busy, or have somehow over looked these suggestions.
- Allow the 2.4G and 5G radio SSIDs to be separated. All other OEMs which use any type of “smartconnect” ability allow that feature to be disabled. Because it doesn’t always work for EVERYONE. There are too many client devices in this world. 2 devices may work, and 2 may not. Allow this separation and it further removes the burden of band-steering. I can lock in my devices to a specific 2.4G or 5G band, and Orbi doesn’t need to worry about moving my devices to the other 2.4G radio. This should help with disconnects. It also allows Netgear to sell more Orbi Satellites. I would be inclined to buy an additional satellite so I have large 5G coverage, rather than moving to 2.4G. Let the user decide, as all your competition allows.
- Allow Orbi node/device-steering to be completely disabled. The Orbi is Fast. VERY FAST! It should not be required to force client devices back to the main Orbi router. If my client device has a good connection to the satellite, then let it stay there, or move on its own if the RSSI drops beyond 75. Most modern devices handle roaming VERY WELL, and do not need your help. Don’t risk a client disconnect by forcing the device to move to the router. Please provide the option to disable all band-steering.
- Please expose the client device, and Orbi Satellite device, RSSI, MCS Data Rate, connected radio, and which Orbi node its connected to. This will allow your users to have troubleshooting ability…AND it will allow better placements of the Satellites if you can show the “REAL” RSSI and MCS of the satellite connections. When a Satellite powers up and gives that white light showing a good connection. What it doesn’t tell you is how stable that connection is. I have two locations in my home that can cause random fluctuations in my signal strength. It will be good one moment, and not good 60 seconds later. I have been FORCED to use a Samsung Android Smartphone with WIFI Analyzer to determine the TRUE quality of a Satellite location because your product refuses to show any detailed information.
- Please allow automatic updates to be DISABLED. Netgear suffers the same problem all manufactures experience. Sometimes you get it WRONG. Sometimes a code update causes more problems. Your customers should be allowed to choose if they want to update, or NOT. This can be resolved via Orbi light illuminations telling the user something needs to be performed. It can also be notified via the Orbi App. But it should be “notify first, then allow the user to accept or decline the update”. Your recent 1.9.x update has caused more problems than it solved. Further making the Orbi NOT SIMPLE.
And there are other “nice to have” features such as vLAN support for guest network. And others…But I would be happy see the above changes made.
These requests are ALREADY part of the command line, but using them is difficult, requires research, and should the user make any changes in the Web GUI, the command line changes are lost.
Please read this, and please make Orbi work. These changes should take no more than 2-4 weeks.
Thank You
- CafetomMay 02, 2017Star
WELL SAID!
If a feature doesn't work, don't offer it. At some level, I am thinking that this is a version 1.OMG product. I should have known that when I bought it, but the marketing of the possibility was intriguing.
What I did find interesting is that some of the features I took for granted in my Nighthawk router simply are not present in the Orbi. And the features that are in the Orbi just don't seem to work as well as they do in the Nighthawk.
If I new i was giving up all those features and functions for the only feature of having a satalite wireless, I would have never purchased this product.
Prove me wrong Netgear. Make it work and implement the features that flash008 suggests.
- Bing-StrollerMay 02, 2017Luminary
An Excellent posting !
For someone to take the time to write such a well thought, informative and constructive post such as this deserves recognition.
I only hope that it is read and given due consideration at the highest levels in the Corridors of Netgear !
- fbraz50May 02, 2017Apprentice
I agree with most of your points and this is well stated. I do have one comment though. Band Steering is a good thing if done right. Most devices are very bad at roaming. This is why all Enterprise equipment has this feature and it tends to work very well in those environments. Granted they are adjusted based on the environment.
