jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
Flash008
May 03, 2017Luminary
Rolling back to 1.8.x.
1.9.x has proven to make my WIFI in my home useless for all devices. I cant use SlingTV, WIFI calling or much of anything that requires a stable connection.
Netgear. Per my previous post, please open the Orbi advance options to allow us to tweak and tune this product to match our needs. You do not know my home, nor my devices, nor my enviroment and any other factors which may prove incompatible with your configuration.
I need control.
Asking me to disable beamforming, MU-MIMO, reduce power levels, and other changes, effectively disables the prime feature set of this product and is not a solution.
BMW asking me to not use anti-roll stability, iDrive, adapative cruise control, other special BMW features, and to keep it under 50MPH, somewhat defeats the purpose of owning a BMW.
- tubastankMay 03, 2017Apprentice
Flash008 wrote:Rolling back to 1.8.x.
I need control.
I tried rolling back 1.8.x yesterday and couldn't. It acted like it was going to work but when the Orbi came back up the version was still 1.9.1.12. Perrhaps you'll have better luck.
If you do, please provide the steps taken to do so.
- Flash008May 03, 2017Luminary
After rollback to 1.8.x I can report 2+ hours straight and not a single problem with SlingTV or WIFI calling (no more than usual with 1.8.x). Version 1.9.x was causing buffer and disconnect problems every 10-30 minutes.
To role back you only need to download 1.8.x files from Netgear Support site. Login to both Orbi router and satellite. Browse to the file and select upload.
It will ask if you want to "downgrade" from the newer version. Say yes. It will reboot and you should be on 1.8.x.
Understand, after reboot/downgrade it will indicate that new 1.9.x update is available. What I do not know is, "will Orbi auto update to 1.9.x again", without my permission. I guess I will know if my client devices begin miss-behaving again. I could block the Orbi IP addresses with my firewall, but then the Orbi lights will come on complaining about “no internet”!!!! I am also using AP mode, not router mode. Hence, blocking the Orbi IP will work for me, but not for someone using Orbi as the internet router.
Netgear, ARE YOU LISTENING?????
- fbraz50May 03, 2017Apprentice
I had to jump through hoops to get this to work. What ends up happening is the Orbi's will auto update themselves once they get online. I wrote up step by step what I did to block the updates in this thread. The section that reads How I solved my problem: outlines the steps I had to to do. Link of post is below.
fbraz50,
Great post for how to block auto-update. I will try that now. Thank You!
Shame this is required, and what solution exist for those who do not have third-party routers/firewalls. I guess it will suck to be them. Trapped on a bad code level until Netgear removes it or pushes a fixed code level.....So sad.
- CafetomMay 03, 2017Star
Rolling back to 1.8.0.6 myself.
When my wife (Mrs. dialup patience) notices a wireless problem it has to be bad.
Flash008. I think asking for things to be open might be a bit too much right now. How about they get things stable to start. Don't do anything else except fix wireless stability. Then maybe we can ask for the standard things that come in most home routers for the past 20 years. :(
Thank You Cafetom for the reply,
I used bad English. Sorry.
What I mean is "OPEN" = advanced options to control band and Orbi device steering. And other advanced options found on most mid-high tier consumer WIFI routers/APs.
I highly suspect device and band steering is the main problem for disconnects. Also allow the 2.4G and 5G BSSID to be separated, along with disabling auto-updates. Look at 1.9.x and the problems it is causing. How do most non-techy users stop Orbi from updating to a code level that clearly should be pulled from the update servers?
So yes, OPEN may be the wrong word.
I sound like a broken record now. Maybe if I repeat the same thing 100 times Netgear will listen. HA HA HA! Did you hear about the kid you wrote a letter to Stanford with only, "Black Lives Matter" 1000 times. He got accepted. Finally, we know the secret to get the attention of large organizations.
- rivetsMay 03, 2017Apprentice
1.9.1.12 has been almost perfect for me and I re-enabled beam forming etc. only seen a single disconnect in three days.
