jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
tubastank
May 03, 2017Apprentice
Flash008 wrote:Rolling back to 1.8.x.
1.9.x has proven to make my WIFI in my home useless for all devices. I cant use SlingTV, WIFI calling or much of anything that requires a stable connection.
Netgear. Per my previous post, please open the Orbi advance options to allow us to tweak and tune this product to match our needs. You do not know my home, nor my devices, nor my enviroment and any other factors which may prove incompatible with your configuration.
I need control.
Asking me to disable beamforming, MU-MIMO, reduce power levels, and other changes, effectively disables the prime feature set of this product and is not a solution.
BMW asking me to not use anti-roll stability, iDrive, adapative cruise control, other special BMW features, and to keep it under 50MPH, somewhat defeats the purpose of owning a BMW.
I tried rolling back 1.8.x yesterday and couldn't. It acted like it was going to work but when the Orbi came back up the version was still 1.9.1.12. Perrhaps you'll have better luck.
If you do, please provide the steps taken to do so.
Flash008
May 03, 2017Luminary
After rollback to 1.8.x I can report 2+ hours straight and not a single problem with SlingTV or WIFI calling (no more than usual with 1.8.x). Version 1.9.x was causing buffer and disconnect problems every 10-30 minutes.
To role back you only need to download 1.8.x files from Netgear Support site. Login to both Orbi router and satellite. Browse to the file and select upload.
It will ask if you want to "downgrade" from the newer version. Say yes. It will reboot and you should be on 1.8.x.
Understand, after reboot/downgrade it will indicate that new 1.9.x update is available. What I do not know is, "will Orbi auto update to 1.9.x again", without my permission. I guess I will know if my client devices begin miss-behaving again. I could block the Orbi IP addresses with my firewall, but then the Orbi lights will come on complaining about “no internet”!!!! I am also using AP mode, not router mode. Hence, blocking the Orbi IP will work for me, but not for someone using Orbi as the internet router.
Netgear, ARE YOU LISTENING?????
