jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
Malik2k1
May 07, 2017Star
Hey Everyone,
So I've spent some time reading the forums and it's evident that some people have found the orbi to be more stable with the new firmware and others have said it's gotten worse. I wanted to share my experience as it's been an odd one to say the least.
My Setup:
ISP Modem (Bridge Mode) -> Netgear Nighthawk (Router) -> Orbi (AP Mode)
When I first got Orbi, I was plagued with reboot issues and after reading suggestions on the forums, I switched the Orbi to AP mode. This stabilized performance and cut down disconnects and all was fine and dandy. I had MUMIMO disabled, beamforming enabled, WMM enabled and both radios (2.4 and 5ghz) at 100% transmit.
With the firmware update on May 5th, my whole setup fell apart and I started seeing latency issues on all iOS devices. I did some more forum research and tinkered with settings, moved Orbi router, moved Orbi satellite, adjusted transmit power and even prayed for a miracle. Nothing worked.
Completely dejected, I decided to unplug my modem, nighthawk and Orbi devices and put things back the way they used to be until a new firmware update would resolve the issues. The strange thing is that everything is working fine now and I have no clue why.
The Orbi router is in my basement and satellite is on the second floor of the house (50-60ft apart) and I'm no longer seeing the latency problems on my iOS devices like before. I have no clue what the made it stable but the household is at peace again without constant nagging that the internet isn't working.
Now not everything is fine and dandy as I do notice my iOS device dropping wifi and reverting to LTE when I'm moving about the house (not in use but in my pocket) but as soon as I unlock the phone it seems to hop onto wifi and function properly.
Not too sure what else to say but I'm hoping you guys have the same luck as I did. I do really enjoy the Orbi as it's much better than anything I've previously used. I wish it wasn't so finicky and I wish netgear got firmware out quicker but then we'd live in a perfect world!
Anyways, the point here is I really hope you guys see similar results in possibly just unplugging the whole system, moving the Orbi devices farther apart and possibly just rebooting all your network devices as I did. I know it seems a bit amateur but it seems to have helped me and hopefully it works for you too!
My Setup:
