jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
Retired_Member
May 16, 2017The router has it's own disconnect issues, but there is definitely a major problem with the connection between router and satellite. If you watch the signal with a Wi-Fi analyzer app, you will probably see the backhaul signal (no SSID) constantly dropping, which takes out devices connected to the satellite with it.
