jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
Retired_Member
Jun 06, 2017The one I was using is a mobile app called Wi-Fi Analyzer or another called Netgear Wi-Fi Analytics. The ones you are using should work if they graph a signal strength over time. The backhaul has no SSID and will be about the same strength as the other signals from the router. If guest network is off, you should 4 different signals coming from the router.
Are any of the devices you use for Hangouts connected to the satellite? I have no drops while streaming either since the network is able to buffer far enough in advance. I don't notice the Echo ir Google Home being disconnected until I ask a question and get the "sorry I'm having trouble connecting" response.
Thanks for looking into this, I've been really curious how it looks for someone with no problems.
Ts937km
Jun 06, 2017Apprentice
I will give it a try tonight. I'l load up a s8 with that product
Yes my main router is in my basement. A satellite is right near where I work and one at the other end of the house by the bedrooms.
Prior to the current production my echo's would do that randomly. Beed weeks since I saw that.
I use my echo's constantly as I use them for home automation, lights etc. No issues at all.
