jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
Retired_Member
Jun 07, 2017Hey TomMac, I am seeing the drop on the 5 GHz and 2.4 GHz backhaul. I don't know if they serve separate purposes but they both drop constantly at different times. I'm seeing the backhaul on channel 157 and I'm in NA. So with guest network off, there are 4 signals coming from the RBR50.
Someone else said that the 2.4 backhaul is only used as a backup in case the 5 GHz fails. I thought that was interesting and may be related to the speed discrepancies some users see.
peteytesting
Jun 07, 2017Hero
hi
the backhaul is only wireless AC on 5 gig , there is no 2.4 gig as far as i know , i think what you will find is the apps just dont like hidden sidd and thats why you are seeing what you are seeing , try transferring a file from one device to another over the orbi router ethernet and sat ethernet , with the router and sat about 10 meters apart you should see 50MB/s and thus proving its a reporting issues and not the transmission its self
pete
