jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
tubastank
Jun 13, 2017Apprentice
Netfixr...if you bought it at Costo you're safe. I bought mine in December 2016 and returned it yesterday. I was only asked "is it broken or did you not like it". Keep your receipt and you'll be fine to return whenever because they don't classify the Orbi as a computer so you can return it anytime.
Good luck.
Good luck.
