jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
peteytesting
Jun 19, 2017Hero
you cant , its not public fw its beta fw and is still needing testing and review
if you want to return it do so via the rma path
Flash008
Jun 19, 2017Luminary
I have provided Netgear with my review of their latest beta firmware.
I have recommended they release it for GA quickly. I believe it will solve many stability problems.
For me. It has been stable. Far better than there last GA release. About the same, if not “a little” better than beta 1.10.0.1 which I used for a while and prevented me reaching for the Advil bottle.
However, I am still holding them accountable for:
- Option to disable auto updates.
- Better GUI visibility for connected clients. RSSI, MCS, and which node they are connected.
- True Mesh ability. No reason those Sat nodes can’t be used as extensions to other Sat nodes.
If Netgear could simply handle those modifications then I think Orbi will be good enough to pass itself as a “Premium” product.
May mercy on Netgear’s soul be given if Lyra and other products are released and/or updated before Orbi has these simple and required changes.
If they push another GA release that brings Orbi back to the disconnect world. I will EBay this thing faster than they can respond with another beta.
