rtparies
Oct 22, 2019Guide
updated my RBR50 to firmware 2.5.0.38 satellites do not appear online
Hello, my RBR50 to firmware 2.5.0.38 last night When i look at the connected devices on the 192.168.1.1 admin page (web interface), it says the satellites are not connected when i look at the netwo...
schumaku
Oct 22, 2019Guru - Experienced User
rtparies wrote:RBR50 to firmware 2.5.0.38 ... When i look at the connected devices on the 192.168.1.1 admin page (web interface), it says the satellites are not connected
when i look at the network map on the orbi app it says it is online.
Wired (hub and spoke, or daisy chain), or wireless, or mixed bckhaul?
- rtpariesOct 22, 2019Guide
My Satellites are wired
not sure what (hub and spoke, or daisy chain) means
they all are connected to a single switch- schumakuOct 22, 2019Guru - Experienced User
Ok, reads familiar to what I have just read about the new WiFi 6 Orbi - a very similar report.
Considering how expensive these are , this is really crappy support and quality.
From what i can tell there is no real support , only community?? is that correct?
- KamsOct 22, 2019Star
Hub and spoke meaning each satellite is connected to the main router directly, like a whle and its spokes
daisy chain means, the 1st satellite is connected to the main router, and the 2nd is connected to the 1st, and so on. all wireless of course
- FURRYe38Oct 22, 2019Guru - Experienced User
What is the MFr and model # of the switch your using with the RBS and RBR?
Have you tried a reset on the RBS and re-add it while in the same room as the RBR to see if it will re-sync correctly, then wire connect it after wards directly to the the back of the RBR?
I updated my RBR and RBS yesterday. The RBS is behind 4 daisy chain Gb LAN switches. HP and D-Link non managed. No issues with the RBS wire connected.
rtparies wrote:My Satellites are wired
they all are connected to a single switch- rtpariesOct 22, 2019Guide
just a note... this config was working until I updating the firmware
