_Asuri
Jun 03, 2019Aspirant
Updating a never before used Orbi Satalite RBS40 impossible?
Ok, so here's a TL;DR version. I've just come home from University and I've been using the RBR40 for a year. My room is only small so I never thought about using the satalite till I was about to ...
_Asuri
I've managed to update the satellite to version 1.12.0.20 but every time I select one of the 2.X firmwares, it says that the firmware isn't compatible.
Jun 03, 2019Guru - Experienced User
AH I should have mentioned, download RBS v2.0.0.74, then you can update directly to v2x on the RBS.
_Asuri wrote:I've managed to update the satellite to version 1.12.0.20 but every time I select one of the 2.X firmwares, it says that the firmware isn't compatible.
