yuonmine
Nov 13, 2021Aspirant
Updating the firmware for my RBR50 and RBS50
My current firmware that I'm on is V1.4.0.18. Any recommendations on how to update to the latest firmware version? Thank you all in advance
CrimpOn
Nov 13, 2021Guru - Experienced User
This is a three step process:
- Update router and satellites using the "Manual Update" tab to firmware V2.2.1.212
https://kb.netgear.com/000060612/RBR50-RBS50-Firmware-Version-2-2-1-212 - Update router and satellites using the Manual Update tab to firmware VV2.3.0.32
- Then update router and satellites to any version after that. Please be aware that Netgear appears to be auto-updating to V2.7.3.22 once firmware reaches a certain level.
I, personally, prefer to connect directly to satellite web pages (http://<ip of satellite>) and select the bottom menu item (Firmware Update).
Hope this is helpful.
yuonmine
Nov 14, 2021Aspirant
Thank you so much. In what order do I need to do the update? I was told do the satellite first. Is that true? Also when updating the satellite can I just plug my cat5 cable directly into the router to update it or do I need to plug it directly into the satellite? Thank do much in advance.
V/r
Hasene
- CrimpOnNov 14, 2021Guru - Experienced User
Yes, the generally accepted practice is to do the satellites first. Personally, I have no idea if that is required, better, or not.
Connecting directly to the router with an ethernet cable is also the recommended practice. A WiFi connection will work, but is not as convenient as a wired connection.
