mark47150
Jan 23, 2023Aspirant
Upgrade from RBR40/RBS20 to RBK50
I bought 3 x RBK50 V2 from Walmart (total of 3 routers and 3 satellites) for $270 total. I understand this will make a 1 router and 3 satellite system. These items can still be returned. I currentl...
- Jan 23, 2023
The main differences between the 40 and 50 series is the wifi backhaul speed support of 866 vs 1733Mpbs. Some minor memory in the HW differences that you won't notice. They both support current wift AC modes and have nothing new in regards to wifi AX modes or wifi 6 so your not really doing any future proofing by getting the 50 series. To future proof some, you'd be looking at something that has AX mode support. If your current system is working, I'd keep it and look at something down the line as Wifi features and spec changes ever so often.
Jan 23, 2023Guru - Experienced User
mark47150
Thanks FURRYe38 and kudos.
I opened one of the packs so that my son could have a dedicated RBS50 hardwired to his gaming PC which greatly reduced some lag issues he was having. Should I swap the remaining RBR50 from that pack with the RBR40 I have already installed? Is it as simple as setting the RBR50 up with the same SSID and password as the RBR40?
- FURRYe38Jan 23, 2023Guru - Experienced User
Yes you can use same SSID name and PW if you want to migrate to the 50 series of course. I do this as well when I bring on a new system. I set it up off line. When that is ready to go, I'll connect the router to the ISP modem and power on the new router, reboot the ISB modem, leave the out going router left ON, and when the new router is ON and ready, just turn OFF the out going router and all my wifi devices auto migrate and connect to the new router.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
