StKittsUser
Nov 14, 2022Tutor
Upgrade LBR20 to 2.7.5.4 via Orbi App
Has anyone been able to upgrade to the latest firmware (2.7.5.4) from the current Orbi app. I have tried a couple of times and the orbi app (v2.20.2.2506) insists that there is no update for v2.6.5...
Nov 14, 2022Guru - Experienced User
Have you tried updating manually through the browser and not using the app?
- StKittsUserNov 14, 2022TutorThat would probably work, but isn't much of a solution when the router is 6 hours away, it's in a remote rental property, hence LTE as the backhaul solution...
One of the benefits I was sold on was the ability for the orbi app to manage the router even when I was not physically present, and that it works even in CGNAT scenarios.- burringtonNov 14, 2022Star
I haven't had need for it so haven't tried it, but I thought there was a way to remotely access the router via the web also?..
- StKittsUserNov 19, 2022TutorYep, that apparently also does not work correctly....
See attachment clearly showing that there is no update, as well as the older version is the running version
