StKittsUser
Nov 14, 2022Tutor
Upgrade LBR20 to 2.7.5.4 via Orbi App
Has anyone been able to upgrade to the latest firmware (2.7.5.4) from the current Orbi app. I have tried a couple of times and the orbi app (v2.20.2.2506) insists that there is no update for v2.6.5...
Nov 14, 2022Guru - Experienced User
Have you tried updating manually through the browser and not using the app?
StKittsUser
Nov 19, 2022Tutor
Yep, that apparently also does not work correctly....
See attachment clearly showing that there is no update, as well as the older version is the running version
