Ra2313
Mar 16, 2024Aspirant
Upgrade router with Orbi RBR40
My existing modem is a C6220 (AC1200). I have an Orbi RBR40 and 2 satellites. My modem is not rated high enough for my internet service so I want to upgrade to CM700. My Orbi is not supported by Net...
Mar 16, 2024Guru - Experienced User
What speeds are you paying for and who's your isp?
It might be just worth upgrading the modem and keeping the orbi if its meeting your needs.
- Ra2313Mar 16, 2024Aspirant
Xfinity 1200 down.
I also worry about security even though I do have Armor. I definitely want to have a router that will have firmware updates
Thanks
- plemansMar 17, 2024Guru - Experienced User
the cm700 doesn't support multigig on xfinity.
I'd look at getting one of the next gen devices that xfinity supports for your modem.
knowledgebase/next-generation-internet - Comcast_Xfinity (reddit.com)
- Ra2313Mar 17, 2024Aspirant
Thanks. The reason I didn't go with a higher modem is the Orbi RBR40 only goes to 866mbps. Would the Orbi/satellites work in the configuration I am suggesting? Chain Modem- New Router-OrbiRBR40/satellites
