Ra2313
Mar 16, 2024Aspirant
Upgrade router with Orbi RBR40
My existing modem is a C6220 (AC1200). I have an Orbi RBR40 and 2 satellites. My modem is not rated high enough for my internet service so I want to upgrade to CM700. My Orbi is not supported by Net...
Mar 16, 2024Guru - Experienced User
What speeds are you paying for and who's your isp?
It might be just worth upgrading the modem and keeping the orbi if its meeting your needs.
Ra2313
Xfinity 1200 down.
I also worry about security even though I do have Armor. I definitely want to have a router that will have firmware updates
Thanks
- plemansMar 17, 2024Guru - Experienced User
the cm700 doesn't support multigig on xfinity.
I'd look at getting one of the next gen devices that xfinity supports for your modem.
knowledgebase/next-generation-internet - Comcast_Xfinity (reddit.com)
- Ra2313Mar 17, 2024Aspirant
Thanks. The reason I didn't go with a higher modem is the Orbi RBR40 only goes to 866mbps. Would the Orbi/satellites work in the configuration I am suggesting? Chain Modem- New Router-OrbiRBR40/satellites
- plemansMar 18, 2024Guru - Experienced User
Even if you don't go multigig, you should still at least go to to docsis 3.1. That'll at least get you gigabit.
And if all you're doing is the cm700, its pointless to upgrade the router as it'll have no problem handling the cm700.
- Ra2313Mar 28, 2024Aspirant
WIll my RBR40 present a security issue since it is not supported any longer?
- CrimpOnMar 28, 2024Guru - Experienced User
I think, "not especially." No Netgear router accepts connections from the internet. Most vulnerabilities are from the LAN side and highly technical. I do not lose sleep over the security of my 8 year old Orbi router.
