UlfL's avatar
UlfL
Upgraded fiber network, but wifi same speed. What to do?
I have a fiber network into the house and the Orbi RBR20 AC220 as wifi. Been 100 Mbit/s on both and worked well. Now I upgraded the fiber to 250 Mbit/s with new router. Wired network in house produces 250 Mbit/s, but the wifi is still on 100Mbit/s. What do I need to do the change the speed on the wifi as well?
Tnx!
/Ulf
    WiFi speed is a function of the device capability and the distance from the WiFi access point.  On the Orbi "app", what does it report for the "Link Rate" to each device?
    If you use Excel, there is a spreadsheet that displays the information for every device:
    https://www.dropbox.com/s/o0eaj5kjs3cpxcc/ORBI%20Soap%20Request.xlsm?dl=0
    • UlfL's avatar
      UlfL
      Hi
      Thank you for answering.
      I go without the excel...
      Chromecast 195 Mbps
      Mobile1 72 Mbps
      PC 520 Mbps (if is my PC , but when I run test pgm I get 95 Mbps)
      Mobile2 520 Mbps
      Mobile3 390 Mbps
      Smart clock 390 Mbps
      Mobile4 144 Mbps
      Speaker 130 Mbps
      IoT device1 72 Mbps
      IoT device2 108 Mbps
      Best /Ulf
      • It certainly looks like most of the mobiles and the computer should support more than 100mbs.
        I am at a loss.
