Timster
Nov 03, 2019Aspirant
Upgraded from cm700 to cm1200 resulting in speed reduction of device of ahrdwired device on Orbi
I exchanged my CM700 with a CM1200. When using the CM700 my PC, conencted through an ORBI would get D/L speeds of 450Mbps. After swapping the CM, I only get 250Mbps. However a speed test in the...
Nov 03, 2019Guru - Experienced User
What website are you using for testing? These can be very unreliable if the server the website uses is slow.
Who's your isp?
Have you tried any other devices?
Are you using any traffic monitoring, parental controls, disney circle, access control to manage the orbi?
What firmware is your orbi on?
- TimsterNov 03, 2019Aspirant
What website are you using for testing? https://www.speedtest.net/ (same as before)
Who's your isp? (Xfinity)
Have you tried any other devices? No, nothing else is ahrdwired
Are you using any traffic monitoring, parental controls, disney circle, access control to manage the orbi? No
What firmware is your orbi on? Latest (just updated)
- FURRYe38Nov 03, 2019Guru - Experienced User
- plemansNov 03, 2019Guru - Experienced User
Speedtest.net lets you change servers. Try a couple different ones. I've had the same server show me lower speeds. Switch to a different one.
Have you tried a factory reset? Never a bad idea if the firmware updated and you changed modems.
I would install Ooklas installable speed test app and compare testing. Sometimes browsers can impact speeds as well. The dedicated speed test app excludes those ads during testing.
Timster wrote:What website are you using for testing? https://www.speedtest.net/ (same as before)
