R_Merther
Apr 15, 2020Aspirant
Upgrading Existing Orbi Mesh WiFi System
My current WiFi system is an Orbi 5 router with two satellites (one upstaires and one down). The router is attached to a 1G fiber cable which is also used for home phone service. I currently get dow...
- Apr 15, 2020
Depends on your Mac hardward and what the adapters are built and designed for. If they max out at around 400-500Mbps then trying Orbi AX won't do anything to improve. Uness the adapters in the Max are AX supporting, then of course this would change the performance.
Apr 15, 2020Guru - Experienced User
Which model Orbi do you have? RBK50 or 20 or 40 series?
50 series Orbi supports near 900Mbps on a wired test:
- R_MertherApr 15, 2020Aspirant
RBR 40 Router. with 2 satellite(s).
The modem is Calix 716GE-I
- FURRYe38Apr 15, 2020Guru - Experienced User
Do you get to spec speeds with a wired PC connected to the ONT?
Possible you might have a router included in the ONT...
The two computers used for business are MAC(s) on the ORBI Wi-Fi mesh system. No computers are hard wired to the ORBI Router
