R_Merther
Apr 15, 2020Aspirant
Upgrading Existing Orbi Mesh WiFi System
My current WiFi system is an Orbi 5 router with two satellites (one upstaires and one down). The router is attached to a 1G fiber cable which is also used for home phone service. I currently get dow...
- Apr 15, 2020
Depends on your Mac hardward and what the adapters are built and designed for. If they max out at around 400-500Mbps then trying Orbi AX won't do anything to improve. Uness the adapters in the Max are AX supporting, then of course this would change the performance.
R_Merther
Understood! I will check the speed as suggested.
Would an "upgrade" to the ORBI WiFi 6 (or Nighthawk Mesh WiFi 6) improve my situation? If so is one better than the other?
R_Merther
Apr 15, 2020Guru - Experienced User
