RussFogg
May 09, 2019Tutor
Upgrading from V1.4.0.18
Hi, just bought the router and satellite and have V1.4.0.18 FW installed. They won’t update via the browser connected via WiFi and read on the community I need to manually upgrade to v2.2.1.212 f...
- May 10, 2019I am sorted..thanks for the help.
Firefox, turning off the Mac FW and now both units are in the latest FW and what a difference on the interfaces and all is doing well.
Thanks for the assistance- appreciate it.
RussFogg
May 10, 2019Tutor
Thanks will do!
Sorting it tonight - went out and got myself an Ethernet adaptor for the Mac so it is done proper.
May 10, 2019Guru - Experienced User
:smileywink:
- RussFoggMay 10, 2019Tutor
Okay I need some help pls...
I am connected via ethernet to the RBS50 satellite, I am on FW V1.4.0.18
According to the tips and tricks if on a V1 FW I should be going to RBS50-V2.0.0.74
Downloaded and uploaded that but get a "This firmware file is incorrect!" error.
What am I doing wrong?
I have also tried to manually update from a V1.4.0.18.img file becuase read somehwere that could be the issue but that also fails with the same incorrect FW error
