RussFogg
May 09, 2019Tutor
Upgrading from V1.4.0.18
Hi, just bought the router and satellite and have V1.4.0.18 FW installed. They won’t update via the browser connected via WiFi and read on the community I need to manually upgrade to v2.2.1.212 f...
- May 10, 2019I am sorted..thanks for the help.
Firefox, turning off the Mac FW and now both units are in the latest FW and what a difference on the interfaces and all is doing well.
Thanks for the assistance- appreciate it.
May 10, 2019Guru - Experienced User
What browser are you using? Safari? Try FireFox.
Be sure you have the right RBS50 FW .img file.
Try a factory reset on the RBS, wait for the connection to be ready, then try to send the img file. I was able to do this on a Windows PC.
Do any of these work?
RBS50 (Orbi Satellite) Firmware Version 1.10.1.2
RBS50 (Orbi Satellite) Firmware Version 1.9.1.12
RBS50 (Orbi Satellite) Firmware Version 1.8.0.6
RBS50 (Orbi Satellite) Firmware Version 1.5.0.12
RBS50 (Orbi Satellite) Firmware Version 1.4.0.34
RussFogg
May 10, 2019Tutor
- FURRYe38May 10, 2019Guru - Experienced User
Awesome. Glad it worked.
Ejoy. :smileywink:
