schmattieboi
Aug 06, 2020Guide
Upgrading ISP branded (Verizon) Orbi RBR50 and Orbi RBS50 to new firmware
I recently was given an Orbi RBR50 and RBS50 satellite from family as they upgraded to something else. This was great for me as these are way better than what I had before. Naturally, I wanted to mak...
CrimpOn
Aug 06, 2020Guru - Experienced User
How did you conclude that this Orbi was supplied by Verizon?
(Something on the product label? Previous owner comments?)
There is no problem with manually loading the same firmware as is already on an Orbi.
You might try to manually install v2.1.4.16 and see if it gives the same error.
- schmattieboiAug 06, 2020Guide
Thanks for the response. Verizon shows up in the top of the Web UI. As for loading the same firmware, I also tried this to the same result.
I've linked pictures if that helps:
Satellite Update Failed with error
- CrimpOnAug 06, 2020Guru - Experienced User
Well, (duh) that pretty much takes care of that question. Thanks.
One customer got satisfaction from Verizon, although his solution may not apply in your specific case:
https://community.netgear.com/t5/Orbi/Verizon-FIOS-sold-Orbi-firmware-replacement/m-p/1772268
On balance, my guess is that you are "stuck". We have a mantra here, "If it ain't broke, please don't try to fix it."
So, if the Verizon firmware works as well as you need, maybe better to give up on the issue.
There is a Chinese hacker who found a way to turn an Orbi router into a satellite. Maybe (just maybe) that technique could be used to convert it from a Verizon firmware to Netgear firmware. But, that's a pretty big gamble when the family wants the "internet to work."
- schmattieboiAug 06, 2020GuideThanks - that seemed to be my conclusion as well.
- FURRYe38Aug 07, 2020Guru - Experienced User
I thought I remembered one posted user mentioning that they had used recovery to send down stock FW to the Verizon RBS and RBR. Something you can try.
schmattieboi wrote:Thanks for the response. Verizon shows up in the top of the Web UI. As for loading the same firmware, I also tried this to the same result.
- schmattieboiAug 07, 2020Guide
Do you mean this?
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
