schmattieboi
Aug 06, 2020Guide
Upgrading ISP branded (Verizon) Orbi RBR50 and Orbi RBS50 to new firmware
I recently was given an Orbi RBR50 and RBS50 satellite from family as they upgraded to something else. This was great for me as these are way better than what I had before. Naturally, I wanted to mak...
CrimpOn
Aug 06, 2020Guru - Experienced User
How did you conclude that this Orbi was supplied by Verizon?
(Something on the product label? Previous owner comments?)
There is no problem with manually loading the same firmware as is already on an Orbi.
You might try to manually install v2.1.4.16 and see if it gives the same error.
schmattieboi
Aug 06, 2020Guide
Thanks for the response. Verizon shows up in the top of the Web UI. As for loading the same firmware, I also tried this to the same result.
I've linked pictures if that helps:
Satellite Update Failed with error
