schmattieboi
Aug 06, 2020Guide
Upgrading ISP branded (Verizon) Orbi RBR50 and Orbi RBS50 to new firmware
I recently was given an Orbi RBR50 and RBS50 satellite from family as they upgraded to something else. This was great for me as these are way better than what I had before. Naturally, I wanted to mak...
schmattieboi
Aug 07, 2020Guide
Do you mean this?
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Aug 07, 2020Guru - Experienced User
Yes, I thought I saw a post a while back that someone managed to convert from Verizon to NG stock using that method. Let us know if you try.
Are the RBS also on Verizon FW? I would probably try converting a RBS first.
schmattieboi wrote:Do you mean this?
- schmattieboiAug 07, 2020Guide
Yes - both are verizon firmware as far as I can tell (see earlier pictures). If I do try it, I will add results as it seems like that kind of information is hard to find.
- FURRYe38Aug 07, 2020Guru - Experienced User
Good Luck. Hope it works.
- Nerdopolis757Sep 17, 2020Tutor
Was able to get the manual firmware update to work on both the Router and the Satellite to REPLACE the lame Verizon firmware. Steps are as follows;
1) Download identical versions of the firmware (example RBR50-V2.5.1.16.img and RBS50-V2.5.1.16.img)
2) Get TFTP software ready to upload (put) firmware on the corresponding devices and set laptop / computer ethernet to static IP of 192.168.1.10 with a subnetmask of 255.255.255.0.
3) Starting with the Satellite
a. Turn off and unplug any ethernet devices
b. Using a paperclip, press and hold the reset button
c. Turn on while holding in reset button
d. After 30 seconds and while the LED is blinking Red, release the reset button
e. Plug ethernet from laptop/computer to Satellite
e. Upload (aka put) the RBS50-Vx.x.x.x.img to 192.168.1.250
Macbook example --> tftp 192.168.1.250 <enter>
bin <enter>
put RBS50-V2.5.1.16.img <enter>
4) After about 20 seconds, the upload should complete. DO NOT POWER OFF ANYTHING.
5) Within 5 minutes, the Satellite should reconnect to the Router
6) Once the Satellite settles down and the top ring LED turns off, repeat the steps above for the Router. DON'T FORGET TO USE THE CORRESPONDING FIRMWARE. The router uses RBR50-Vx.x.x.x.img. Notice the only difference is the second "R". :)
7) The Router, once restarted, will want to run through the ORBI mobile app setup. Or you can connect to http://192.168.1.1.
