makoychan's avatar
makoychan
Upgrading to Orbi concrete bldg.
Hi,   Has anybody had experiece setting up an orbi wifi system on a concerte bldg. My family has a 5 floors concrete residential bldg. i am planning upgrade the wifi system there, the ceiling hei...
  • FURRYe38's avatar
    Mar 26, 2019
    Any chance of placing wired APs at each location? Concrete is going to play major havoc on Orbi and wifi MESH. You can use the system with the satellites connected via ethernet LAN cable if you have the abililty to do that.
    5Ghz doesn't work well with concrete.
