Joevberg
Jun 06, 2020Aspirant
Upgrading to wifi 6 worth it?
I currently have rbk50 with 2 sattelites, I use both sattelites to connect tvs and media devices via ethernet. I have 400 fios service. Generally have no internet issues except not a real strong signa...
Joevberg
Thank you. I dont plan on it at this point but there was a great deal I could get on one and if i found a buyer for my current than I would because the money wouldn't be much.
CrimpOn
Jun 06, 2020Guru - Experienced User
Well, now that's a "horse of a different color." (what the heck does that mean?) A "good deal" changes one's perspective.
In that case, it might be worth a few minutes to browse the AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
I have looked very briefly at that forum. My impression is that some people report "good things" about the product, while others are frustrated by a lack of features that they assumed would be on the product. Splitting 2.4G and 5G might be impossible on that platform. Disney Circle may not be supported yet. etc. etc. I should think it would not take very long to get a sense of how the AX product is being received.
- FURRYe38Jun 07, 2020Guru - Experienced User
One can always return the AX system if one doesn't find it to there liking. :smileywink:
If you find a system at cheap price, one can alwasy use a dfferent router that has more features and use either Orbi system in AP mode as well for good wifi.
Good Luck.
- JetdriveJun 08, 2020Luminary
Another thing to consider is that Wifi 6E routers will be out by the end of the year with a totally new band -- 6 ghz on top of the current 2.4 and 5 ghz bands. It seems to me, especiallly if you don't currently have many Wifi 6 devices, that it would be better to wait for the Wifi 6E equipment.
I suspect when Wifi 6E comes out, the current Wifi 6 routers will drastically drop in price due to the missing band.
