AKLGUY
Jun 06, 2021Apprentice
Upgrading to WIFI AX
Hi Crew. I currently have the RBK50 (WIFI 5 series) which does me great for the moment. But I am upgrading all my Laptops and Tablets (already a few phones have WIFI 6) so thinking of the RBK752/RB...
AKLGUY
Thank you for that. That is what I assumed
I did read that the WIFI 5 series wont mesh/go well with the new WIFI 6 series and I did just want to put a cheaper WP down in the garage I might just get one from a different vender and cal it a different name. Keep with my Orbi for the house
CrimpOn
Jun 07, 2021Guru - Experienced User
AKLGUY wrote:Thank you for that. That is what I assumed
My understanding is that ethernet connection for the Orbi WiFi 5 satellite works fine. WiFi 'backhaul' is not possible because they have different radio chips and WiFi 6 models use 802.11ax for the backhaul link. I would first try the RBS50 with ethernet backhaul before looking at anything else.
Netgear pricing makes packages more attractive than individual purchases. For example, Amazon has the RBK752 at $349US and the RBK753 at $452US. That second satellite thus costs $103. Buying one RBS750 satellite is $229US. So, the package saves $103 over buying a two pack and adding the satellite later. (The package savings is not as great for the 850 product.)
- FURRYe38Jun 07, 2021Guru - Experienced User
Yes you can connect RBS AC to Orbi AX via Ethernet only. Not compatible via wireless.
