MrVirgilio
Nov 08, 2018Aspirant
upnp doesnt work with OrbiRBR40
I have cameras and my old cable modem and router worked fine but when I went to the Orbi router it says my Q-See will not work - UPNP. Help.
Nov 08, 2018Guru - Experienced User
What FW is currently loaded?
- MrVirgilioJan 09, 2019Aspirant
Model is RBR40 with 3 Satellites, I am direct connected to the Q-See router. I can see the cameras at the device but not on Iphone via the app. Port forward fails. Not sure what to do next.
What FW is currently loaded? How do I know?
What is the Mfr and model# of the ISP modem the NG router is connected too?ISP Modem is u10c135.10 It says Spectrum on it. only FCC id
My Setup (Cable 900Mb/50Mb)CM1100>XR450> > EX7700 (Wireless Extender)
Additional NG HW: Orbi CBK40(Gateway Mode), R7800, EX7500/EX7700 and WNHDE111- FURRYe38Jan 10, 2019Guru - Experienced User
If the modem already has a built in router, then having two routers on the same line will cause problems like this for uPnP.
If so, then I recommend you contact your ISP have them help you bridge the modem if possible.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
