MrVirgilio
Nov 08, 2018Aspirant
upnp doesnt work with OrbiRBR40
I have cameras and my old cable modem and router worked fine but when I went to the Orbi router it says my Q-See will not work - UPNP. Help.
ekhalil
Jan 10, 2019Master
If the Q-See supports UPnP, do you have UPnP activated in Orbi?
Otherwise you need to setup proper port forwarding (according to the camera system specs, probably need to open ports 85 and 6036). Port forwarding can be set under advanced settings in Orbi:
