miguelangelnet
Nov 05, 2021Guide
Upstream light blinking with no internet issues.
My Firmware Version is V4.6.5.8_2.0.54, and I have a v3 before, with both I had the upstream light blinking all the time. There is no connectivity issues, so, internet works fine, even with the v4 lo...
Nov 09, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
miguelangelnet
Nov 09, 2021Guide
I didn’t try the factory reset after update the firmware. I’ll try it and put the result here.
Thanks!
Thanks!
