sixmassive
Nov 01, 2018Tutor
URL "^0" cannot be found on server
I'm trying to download from iTunes but it gives me an error when connect to my ORBI. I can download from my hotspot.
are there some security settings i need to change?
thanks
Nov 01, 2018Guru - Experienced User
What FW is currently loaded?
Wired or wirelessly connected to the Orbi?
What device are you using for iTunes?
Blanca_O
Nov 08, 2018NETGEAR Employee Retired
Hi sixmassive
We’d greatly appreciate hearing your feedback letting us know if you need further assistance. It would be best that you'll answer FURRYe38's question for us to check this further.
Blanca
Community Team
- sixmassiveNov 13, 2018Tutor
I was having issue with webpages redirecting me to the router log in. I reset the router, and do not have that problem any more.
Itunes is still an issue. We have a broad band service, and the ORBI is wired directly to the modem. There is no number or info on the route. We recently had an older linksys router and everything worked fine. We upgraded to a mesh system due to the construction of the house.
- FURRYe38Nov 13, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?Wired or wirelessly connected to the Orbi?
Also, We are on a MACBOOK air
We have an RBR40 firmware version V2.2.1.210
