Lv23
Oct 11, 2020Follower
USB connection
Wondering how to connect a USB device to Orbi WiFi router/modem combo. Is there an external device I can purchase to make connection since there is not a USB port on Orbi.
Mikey94025
Oct 11, 2020Hero
It depends on what type of device and why you want to connect something via USB to your Orbi network. It also may not be a good idea or not the best way to accomplish what you're trying to do. For example:
- Are you trying to connect a USB printer? Not supported, but there are some "usb print server" devices available. I usually wouldn't recommend them because usually it's better to share such a printer via an always-on Windows desktop or something like that.
- Are you trying to connect a USB drive and get network storage? Again, not supported and performance of such things is usually poor compared to alternative solutions.
- FURRYe38Oct 11, 2020Guru - Experienced User
