godot
Nov 24, 2019Tutor
USB Hard Drive with AC3000 (RBK50)?
The Cliff Notes version: I just set up my new Orbi AC 3000. It is working beautifully. I plugged in my USB Hard Drive into the Orbi Router (not the satellite) so that I can backup my MacBookPro ...
- Nov 24, 2019
I believe you are on the right track. Others have mentioned using their old Apple WiFi routers in this manner. The key is that the old router get an IP address from the primary router (Orbi). Also a good idea to disable WiFi on the old router.
Good Luck
godot
Nov 24, 2019Tutor
Hi CrimpOn ,
Thanks for your reply.
I had read some other posts which addressed this issue, but I didn't know if, between those posts and now, additional functionality had been added via firmware updates. That's too bad since the available USB jack was the main reason I chose Orbi over less expensive routers!
Since my USB Hard Drive worked when it was plugged into my old router, I am hoping the following work-around will work:
Configure my old router into "bridge mode" and connect it via ethernet cable to the Orbi Router.
Plug the USB Hard Drive into the old router.
Cross my fingers.
CrimpOn
Nov 24, 2019Guru - Experienced User
Good Luck
- godotNov 24, 2019Tutor
Thanks for the tips!
