DaveElisa
Jul 10, 2018Aspirant
Use an RBR20 as an Access Point without connecting via ethernet?
I bought an Orbi router (RBR40) and single satellite system. It's connected via ethernet to my cable modem, which does not have wifi. I installed the satellite upstairs but the FireTV, iPhones, Alexa...
st_shaw
Jul 10, 2018Master
DaveElisa wrote:
I bought an Orbi router (RBR40) and single satellite system. It's connected via ethernet to my cable modem, which does not have wifi. I installed the satellite upstairs but the FireTV, iPhones, Alexa, etc. seem to be needing more wifi bandwidth. I went into the local Best Buy and talked with a network guy there and he recommended buying an additional Orbi router/satellite combo and setting up the second router (RBR20) as an Access point. From reading the forums here it seems that it is possible, but only if the RBR20 AP is connected to the RBR40 (router) via ethernet.
Is there a way to provide a strong wifi signal (stronger than satellite) without using ethernet? My other options are Orbi for business, eero, etc. I'd prefer to use the Orbi gear that I have but I'm starting to think the guy at Best Buy made it sound as if it would do something it won't do.
Any suggestions?
Thanks,
-dave
Yes, access point mode requires a wired connection.
You should be able to add additional RBS40 satelites to your existing system.
