alban1107
Sep 15, 2019Aspirant
use ethernet port of the router at the same time as the orbi's one
Hello, I don't have enough ethernet ports on the orbi (only 1 excluded the one connected to the router) so I was wondering if it is possible to use the router's ethernet ports as the same time to h...
- Sep 15, 2019
In what mode do you have your Orbi configured?
- If Orbi is in AP Mode then you can use the Ethernet ports of your ISP Router.
- If Orbi is in Router Mode, then you can't use the Ethernet ports on your ISP router, otherwise your devices will be located on two different networks and will not be possible to communicate between them. Also if Orbi is configured in Router Mode please make sure that the ISP Router is bridged, set to Passthrough mode or forwarded to DMZ.
Please note that you can always connect a simple switch to Orbi to provide you with more Ethernet ports.
Sep 15, 2019Guru - Experienced User
Agreed with ekhalil statement. But you didn't really tell us much. Are you talking the orbi router versus the satellite or do you have another router in the mix?
If you're talking orbi router and orbi satellites and not another device mixed in, you can connect to any of the lan ports (modem for the wan port) and use them. You can even add in a switch if needed as ekhalil pointed out.
So basically if this doesn't help, we need more details on what all devices you're running. Model numbers are the best to include with details.
- alban1107Sep 15, 2019AspirantSorry I was talking of using the modem’s Ethernet port, the satellite had nothing to do with it. I mistook the modem and the router. But I have my answer now so thank you.
