Yogiwalsh's avatar
Yogiwalsh
Follower
Jan 18, 2020
Use my Orbi RBK50 as single point of connection?
Hi, appreciate your advice.
I have installed and connected my Orbi RBR50 to my internet providers modem/router however I am experiencing some conflict (connection is not always stable) between the two.
So, can I get rid of my internet services modem/router and simply use my Orbi RBR50, only.
Many thanks,
Sean
  • CrimpOn's avatar
    CrimpOn
    No.  There is one specific model of Orbi that contains a DOCSIS 3.0 modem and can be connected directly to the cable feed.  All the other models require an internet modem.
  • FURRYe38's avatar
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Many thanks,
    Sean
