kbdci's avatar
kbdci
Use Orbi alongside current R6300v2 router
I am currently using a Netgear R6300v2 router but cannot reach all parts of my residence without at least 2 extenders. I would like to use the ORBI for wifi and continue to use the R6300 for wired in...
  • TheEther's avatar
    TheEther
    Feb 26, 2017
    Just following the on screen instructions to set it up as an Access Point.
    BTW, you don't have to turn off the Wi-Fi on your R6300.  If you have a particularly large house that even the Orbi cannot cover reliably, then the R6300 can be used to provide additional coverage.  Or you can use the R6300 purely for guest Wi-Fi.
