ChezStevens's avatar
Aug 09, 2022
Use ORBI LBR20 LTE in failover to Netgear LAX20 LTE router
Hi folks, Hope you can help. Due to lousy internet connection using French telecom provider (10mbps down, 1mbps up) we now use Free Sim data plans in both Orbi LBR20 & Netgear LAX20 LTE routers (210...
  • plemans's avatar
    Aug 09, 2022
    As far as I can tell, failover will switch when the connection stops working. So if your isp stops your connection at 210gb, it should work. If they step it down to "low data rate" but the connection still works, then I'm not sure if it'll switch over.
    Again, neither device is load balancing so there isn't a way to set it in the settings to split the 2.
    And I dont have either device to see if there's a way to set them to disable after a certain amount of data is used.
    A bit funny how the lax20 gets the much lower speeds. Have you tried swapping sim cards? maybe one was provisioned different.
