Wim_Merlijn
Jan 24, 2022Tutor
Use RBR50 as a satelite
Hi, I do have a RBK50 (with RBR50 and RBS50) and want to extend with a RBS50. But can't purchase new RBS50. So I a thinking of buying Wifi 6 router (RBK852) and use the RBR50 as a satelite of the...
- Jan 24, 2022
Not as a satellite. you can hardwire it in and set it up as its own access point
Jan 24, 2022Guru - Experienced User
With the RBR50 system, there's several satellites you can use.
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
- Wim_MerlijnJan 24, 2022Tutor
Thanks for your quick reply.
But is it also possible to use the RBR50 as a satelite of a new Netgear Orbi router?
- plemansJan 24, 2022Guru - Experienced User
Okay and thanks again.
Best way is to find/ buy one of the satelites:RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
