Wim_Merlijn
Jan 24, 2022Tutor
Use RBR50 as a satelite
Hi, I do have a RBK50 (with RBR50 and RBS50) and want to extend with a RBS50. But can't purchase new RBS50. So I a thinking of buying Wifi 6 router (RBK852) and use the RBR50 as a satelite of the...
- Jan 24, 2022
Not as a satellite. you can hardwire it in and set it up as its own access point
Jan 24, 2022Guru - Experienced User
With the RBR50 system, there's several satellites you can use.
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Wim_Merlijn
Jan 24, 2022Tutor
Thanks for your quick reply.
But is it also possible to use the RBR50 as a satelite of a new Netgear Orbi router?
- plemansJan 24, 2022Guru - Experienced User
- Wim_MerlijnJan 24, 2022Tutor
Okay and thanks again.
Best way is to find/ buy one of the satelites:RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Best way or cheapest?
I've seen several of the "kits' on amazon for renewed.I've bought them before just for the satellites as it was cheaper to buy a kit and sell the router than it was to just buy a satellite.
