macjohn
Dec 04, 2018Guide
using 2.4 vs 5 Ghz..
Hello,
I have a few devices which operate only on the 2.4 Gz band...how do I ensure that these devices will only connect via 2.4 and not try to
connect via 5 ? None of them are showing up as conn...
macjohn
Dec 04, 2018Guide
Hello,
I appreciate everyone's replies and suggestions; I will try them...
If my devices (Nest Protect CO/smoke alarms) are not connectiing to my wireless network and they are only able to via 2.4Gz band why won't they show up on my list of attached devices ? They can talk to each other, but just won't show up on my network.
ekhalil
Dec 04, 2018Master
This can be caused by that your Nest Protect devices were previously connected to another router with the same SSID?
Please check this:
https://community.netgear.com/t5/Orbi/Orbi-and-Nest-Protect-issues/m-p/1159980/highlight/true#M857
Please check this:
- macjohnDec 04, 2018Guide
Hi,
Thank you for the link...earlier this year I had done what is described several times and the products show up on my attached devices list for
about 2 minutes, then are removed from the list back onto my un-attached list. It is frustrating,
Thanks again, and I will attempt another re-set...I appreciate your input
