kywong
Apr 05, 2020Aspirant
Using 2 routers RBR20
I have 2 RBR20 routers. Can I use one of them as satellite or access point? If so, how to configure it?
ekhalil
Apr 05, 2020Master
You can use one of the routers as an AP by connecting it wired to the first router and set it in AP mode.
Please make sure that the two routers use different radio channels.
- kywongApr 05, 2020Aspirant
My intended connection is gateway router to switch to the 2 rbr20s with one ethernet cable from switch to internet port of first RBR20 and another ethernet cable from switch to the ethernet port of second RBR20. Will this work?
