kywong
Apr 05, 2020Aspirant
Using 2 routers RBR20
I have 2 RBR20 routers. Can I use one of them as satellite or access point? If so, how to configure it?
kywong
My intended connection is gateway router to switch to the 2 rbr20s with one ethernet cable from switch to internet port of first RBR20 and another ethernet cable from switch to the ethernet port of second RBR20. Will this work?
ekhalil
Apr 05, 2020Master
No, you have to connect the cable from a LAN Port from the first RBR20 to the WAN or LAN ports of the second RBR20 (the one in AP mode).
