JohnMordaunt
Jul 04, 2020Aspirant
Using a Netgear D6400 Modem/router as a modem only with a Orbi RBR50
I set the D6400 to modem only and rebooted it, then powered it off for 2 minutes. I plugged the Orbi router into the modems internet port and powered on the modem. I waited until the modem was powere...
- Jul 10, 2020
After 4 Factory resets of the Netgear D6400 and setting it up until I could set it to modem only, my orbi finally decided to accept that there was a modem there that it could use. I hope this helps anyone with similar issues.
CrimpOn
Jul 04, 2020Guru - Experienced User
JohnMordaunt wrote:Can anyone tell me what is wrong?
We usually start by asking, "What has changed?" and some more information.
- Is this the initial installation, or was the D6400 in use for some time prior to adding the Orbi?
- Is the D6400 connected to a DSL line or to a cable modem?
- Does the Orbi report its WAN address as a "public" address or a "private" address?
Private addresses begin with 192.168, 10.0, or 172.16 through 172.32. - What performance do you get when the Orbi is removed and a device is plugged directly into the D6400?
