JohnMordaunt
Jul 04, 2020Aspirant
Using a Netgear D6400 Modem/router as a modem only with a Orbi RBR50
I set the D6400 to modem only and rebooted it, then powered it off for 2 minutes. I plugged the Orbi router into the modems internet port and powered on the modem. I waited until the modem was powere...
- Jul 10, 2020
After 4 Factory resets of the Netgear D6400 and setting it up until I could set it to modem only, my orbi finally decided to accept that there was a modem there that it could use. I hope this helps anyone with similar issues.
Jul 04, 2020Guru - Experienced User
Has a power OFF of the modem and RBR for 1 minute then back on been performed?
JohnMordaunt wrote:I set the D6400 to modem only and rebooted it, then powered it off for 2 minutes. I plugged the Orbi router into the modems internet port and powered on the modem. I waited until the modem was powered up and then powered the orbi on. I connected to the Orbi ansd set it up and it reported that all was good, BUT I cannot stream from Netflix, BBC iPlayer or Disney. Any other attempt to access the internet is extremely slow almost dialup speeds. Can anyone tell me what is wrong?
