JohnMordaunt
Jul 04, 2020Aspirant
Using a Netgear D6400 Modem/router as a modem only with a Orbi RBR50
I set the D6400 to modem only and rebooted it, then powered it off for 2 minutes. I plugged the Orbi router into the modems internet port and powered on the modem. I waited until the modem was powere...
- Jul 10, 2020
After 4 Factory resets of the Netgear D6400 and setting it up until I could set it to modem only, my orbi finally decided to accept that there was a modem there that it could use. I hope this helps anyone with similar issues.
JohnMordaunt
Jul 05, 2020Aspirant
I have had the D6400 modem/router since June 2015 and it is connected to a DSL line. The D6400 works perfectly but there are a few dead spots in its coverage and we now have more devices than it can handle. THe Orbi reports it address as private (starting with 198.168). When the Orbi is removed the performace from the D6400 is as before very good with a few dead spots in its coverage.
The Orbi firmware is V2.5.1.16. The D6400 firmware is V1.0.0.88_1.0.88. THe modem and the RBR were powered off for two minutes, with the RBR being powered on after the modem was fully powered back on. My house is in the UK and not very big the D6400 covered it quite well.
When the Orbi is used as an access point, that is with the D6400 used as a modem router and the Orbi just plugged into one off the ethernet ports not login into the ISP it covers all the house with no dead spots and access all streaming sites very fast.
I only have issues when trying to use the D6400 as a modem only. Is there anything else I have to do on the D6400 apart from setting the device mode to modem only, and plugging the Orbi into the D6400 internet port and setting the Orbi to login to the ISP.
Jul 05, 2020Guru - Experienced User
Something to post about in the DSL modem forum:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
There maybe additional settings on the modem that is needed. Contact the ISP aswell for ISP acocunt information that maybe needed on the RBR.
JohnMordaunt wrote:I have had the D6400 modem/router since June 2015 and it is connected to a DSL line. The D6400 works perfectly but there are a few dead spots in its coverage and we now have more devices than it can handle. THe Orbi reports it address as private (starting with 198.168). When the Orbi is removed the performace from the D6400 is as before very good with a few dead spots in its coverage.
- JohnMordauntJul 10, 2020Aspirant
- FURRYe38Jul 10, 2020Guru - Experienced User
Enjoy. :smileywink:
