ETCEric
Jun 29, 2020Follower
Using a rbk50 as a AP for a rbk752
Just purchased the RBK742 to replace a RBK50 that stop sending traffic on it's wired ports. Can I use the RBK50 as a AP for the RBK742? Plan to use a wired connection for the backhaul for the RBK50 S...
Jun 29, 2020Guru - Experienced User
The RBR50 can be used in wired AP as a 2ndary wifi source. It would need to be using different channels far apart from the RBR750s channels.
The RBS50 can only be connected to the RBR750 as a wired RBS.
Be sure to post about your Orbi AX questions in the Orbi AX forum
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
