Rayandbrenda
May 26, 2019Aspirant
Using a RBW30 with RBR50 and RBS50
I'm considering using a RBW30 as a second satellite for my RBK50 system. I know the backhaul is slower but does anyone know if the backhaul to the RBS50 will be degraded or will it still operate at t...
May 26, 2019Guru - Experienced User
You might have to try that out and see. Most users on here usually keep with the same RBS units for additional coverage. I presume the backhaul should not degrade entirely if you add the RBW.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
